Single piece rear main seal - stud
Old May 23, 2009 | 10:13 AM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
There is a stud that is part of the single piece rear main seal. I think that this is pressed in. The old block is cracked and I purchased a zz4 block. I am rebiulding the motor by using as many of the old parts as possible, transfering them from the old block to the ZZ4 block.
Is this one stud actually pressed in? To retreive the existing one from the cracked block should I put one or two nuts on it and pulled it out?
Old May 23, 2009 | 11:21 AM
Guest
Guest
Posts: n/a
Re: Single piece rear main seal - stud
Its threaded. Ideally, you need a torx socket to get it off although I've used vise grips. They are usually in there pretty good as well, so if it breaks dont be surprised although I've never had one break they just always felt at the verge of doing so.
Old May 23, 2009 | 01:28 PM
Vader's Avatar
Vise-Grips are for welding, or holding a loose fender on your '67 F-100. If you want to back out a stud, use jamb nuts. When that fails, use these:
Regular water pump pliers won't work. You need ChanNelLock 410s.
1992 Trans Am
May 10, 2023 07:19 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Reborn756
Sep 4, 2015 03:42 AM
86White_T/A305
Aug 17, 2015 12:16 AM
