L98 engine servicing limits
Old May 24, 2009 | 10:09 AM
Kodfish's Avatar
Car: 1990 IROC
Engine: 5.7 TPI
I have a 90 iroc L98 engine and I'm currently rebuilding it. I'm wondering does anyone has the specs on the limits the crank and block can be bored/undersized too? I would like to keep the displacement stock and just hone the parts out but if I must bore them out, what size do you guys suggest. This is my first engine rebuild and would like some advice. I'm going with 200cc heads, Mini Ram, zz9 cam, edelbrock headers and 52mm throttle body. I have a haynes manual but I'm not sure if the specs in the overhaul sections are accurate. You guys have more experience with the cars than the techs in the book. Thanks a bunch
Kod
Vintageracer
Jan 10, 2020 05:33 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
TheExaminer
Aug 19, 2015 10:07 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
matthew911
Aug 12, 2015 09:38 AM
