How to hard wire the battery?
Old May 24, 2009 | 02:32 PM
usmciroc's Avatar
I have this mysterious power drain on the battery and cant figure it out. I want to hard wire the battery with interior switch. Are there kits out there or how would I go about it?
Old May 24, 2009 | 04:06 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: How to hard wire the battery?
Not unless you use a similar type master switch like the drag racers use at the rear of the car when the battery is installed at the rear. It needs to be big enough to handle cranking amperage through the switch.
I'd just find out why the battery is draining.
Old May 25, 2009 | 10:36 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
That's right. An easy way is to connect a multimeter on current setting inbetween your battery and positive terminals. Then pull fuses and see which one cuts off the current flow. You'll know it's on that circuit. That'll narrow it down.
eightsixseven
Dec 16, 2024 01:50 PM
Street Lethal
Apr 30, 2019 12:14 PM
Dialed_In
Aug 20, 2015 01:45 PM
Rakim_RS25TH
Aug 18, 2015 09:32 PM
