Changing gear oil in a 92 tbi
Old May 26, 2009 | 03:25 AM
goalieforlife's Avatar
Car: 1991 Pontiac Trans Am GTA
Engine: V8 305
Transmission: Automatic Transmission
when is it recommended and what kind of process is it?
Old May 26, 2009 | 07:29 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Changing gear oil in a 92 tbi
Should you be unsure when the last change was, time has come to service it. Drop the cover (which will drain the oil). Clean the housing and diff cover of RTV and/or gasket remains. Button up with a new bead of RTV or a new gasket. Fill up--the fill plug is located on the top pass side of the pumkin). For type of fluid and amount, check the following link:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Old May 26, 2009 | 01:53 PM
Engine: V8 305
this is helpful thanks.
I have no idea when the last change was, I have had the car for 2 years and I doubt the previous owner changed it so I do believe the time has come to change it.
Old May 26, 2009 | 05:02 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
time to change . when cover is off , clean inside . i normally use mineral spirits in a squirt can or spray bottle , then blow out with compressed air . might want to think about a good synthetic gear lube . i like mobil 1 75w90 . good luck .
Old May 26, 2009 | 06:57 PM
Engine: V8 305
i read somewhere (can't remember where) that once that cover is off its difficult to put back on, especially if its never been changed before. It is possible that it never been changed. what problems may I find?
Old May 26, 2009 | 09:24 PM
JamesC's Avatar
If all is cleaned well, I can't imagine there'd be a problem--at least I've never experienced one.
JamesC
camaro11j
Sep 19, 2018 08:49 AM
maroe624
Apr 16, 2017 08:29 AM
Navy8125
Aug 21, 2015 09:32 AM
92camaroJoe
Aug 13, 2015 06:07 AM
