starting trouble
Old May 29, 2009 | 01:54 AM
dwight21's Avatar
starting trouble
i have to use starting fluid to start my 91 5.0. once it fires it runs good ive replaced my tps,injectors,regulator,and fuel filter ! and the security light is on on the dash. any ideas?
Old May 29, 2009 | 02:03 AM
dwight21's Avatar
Re: starting trouble
plesae help
Old May 29, 2009 | 02:38 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
I had this problem once, right after I bought my '91 RS 305, but once I got it started, I never had that problem again, and my security light was not lit. I was using the original key in the original steering column with the original VATS module and computer. I did have a problem with the VATS (security) in my sister's '90 firebird that had had it's steering column and ignition key replaced, but the symptoms were entirely different. I ended up making a new resistor that had the same resistance as the car's original ignition key.
Old May 29, 2009 | 03:09 PM
dwight21's Avatar
it has a aftermarket ignishion and key. and it dont have the chip in the key could this be my problem?
Old May 29, 2009 | 05:02 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
most likely. this is the kind of info you should include in your first post. You'll have to try all 13 different resistances( is that a word? ) but this is easy with an assortment from radio shack. I think it cost me less than $20.
bryan623
Mar 22, 2021 06:43 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
djmarch
Aug 19, 2015 12:07 PM
EFR2000
Aug 18, 2015 08:54 PM
