Thinking of boring out my engine.
Old May 31, 2009 | 12:49 AM
805camaro805's Avatar
Car: 91 Rs Camaro
Engine: 305 tbi
Transmission: 700 r4
I have a 91 rs camaro. 305 5 liter throttle body, and im looking for a way to up my horse power. What else would you recommend beside boring it out. What size would you bore it and where about or who would i take it to.
Thanks,
805camaro805
Old May 31, 2009 | 01:52 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Re: Thinking of boring out my engine.
If it doesn't need a bore, don't bore it. You don't bore an engine for power gains. You bore an engine for maintenance. You won't get any appreciable power gains from an overbore.
Old May 31, 2009 | 05:48 AM
Rich2279's Avatar
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
Thanks,
805camaro805
I know someone will post this so I might as well be the 1st....upgrading to a 350 would be a great way to go.
Old May 31, 2009 | 11:06 PM
Car: 91 Rs Camaro
Engine: 305 tbi
Who would you go to, to get it bored out? Also you think bore it to a 350 then switch out the crank and everything
Old May 31, 2009 | 11:16 PM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
A 350 and 305 use the same crank, you need a new block and pistons if you want a 350. You could never bore a 305 enough to give it a 4.00" bore.
Engines used to be bored out for power, but that was back when cylinder walls were so thick that you could bore them out as much as 1/8" (which would actually turn a 305 into a 350...), but now the most you would ever want to overbore an engine is .060".
Edit: You can take a block to most auto parts stores and they'll send it to their machine shop to bore it, or you can take it to any automotive machine shop.
Old May 31, 2009 | 11:29 PM
kkingsrulee's Avatar
Car: 1990 Camaro RS
Engine: V8 305 TBI
Transmission: W/C T5
Axle/Gears: 3.08
Good luck trying to bore through those water jackets trying to bump it from 5.0 to 5.7 liters.
I believe the maximum you can bore the 305 cylinder walls is like 335 or something like that.
Old May 31, 2009 | 11:54 PM
BASSETT IROC 85's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 355
Axle/Gears: 7.5 inch 342
I agree A 350 swap be the best bang for the buck.
Old Jun 1, 2009 | 12:01 AM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
I disagree, he could just put a big shot of nitrous on his 305.
Old Jun 1, 2009 | 09:52 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
That's only true if you can get the bottle refilled for free every time. For the rest of us, who can't get free nitrous refills, the 350 is still the best bet.
Old Jun 1, 2009 | 10:51 AM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
Yeah... i was being sarcastic, which is what that: was supposed to imply. I do agree, if he's gonna rebuild an engine and wants performance, more cubes is the way to go.
Old Jun 1, 2009 | 12:27 PM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
Like someone else stated, you don't bore out the cylinders for power, you do it because it NEEDS it when you're rebuilding a motor. If you were to tear apart your motor for the specific reason of boring it out for more power then please...go buy a Hon-duh.
Jake_92RS
Jan 28, 2020 10:37 PM
midge54
Jan 29, 2017 07:00 PM
gta90
Sep 15, 2015 04:00 PM
NinjaNife
Aug 23, 2015 11:49 AM
