91 roller engine & brackets into 85 TPI Z28
Car: 85 Z28
Axle/Gears: stock
Situation:
I have a 85 TPI Z28. I have a 91 TPI complete motor with Alternator, P/S, AC, flywheel, the motor is absoluterly complete. I would like to put the 91 motor into my 85 Camaro because of the roller cam & lifters, 1 peice rear main seal, and the 1 belt serpentine system. The main thing I wish to get out of this swap is the roller short block and the 1 belt serpentine system. If I have to change heads so that my 85 intake bolts right on (which I plan on upgrading to a TPIS), I am cool with that but I would like to try and keep the heads as they are Aluminium L98 heads. Other than the fact that may have to swap out the intake base or the heads, will this work?
84z96L31vortec
Aug 20, 2017 12:16 AM
Fast355
Dec 2, 2016 06:33 PM
red90IROCls1
Aug 25, 2015 06:56 AM
