Intake Bolt
Old Jun 1, 2009 | 11:47 AM
JaggedJames24's Avatar
Car: 89' Camaro
Engine: 350 SBC
Transmission: Turbo 350
Intake Bolt
I want to start out by thanking everyone for there help on my last post
But I have a problem I was removing my Intake manafold
when I got to the last bolt the head stipped of
I tried PB blaster berfore I started but it was rusted to the intake
I have tryed JB Welding a wrench to try to break it free
I cant get a socket on it theres not much room
any thought?
Thanks,
Old Jun 1, 2009 | 12:45 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: Intake Bolt
If you cant get a socket on there, but have enough room to get a wrench, try getting a slightly undersized cheapy open ended wrench and force it on (hammer, etc).
If it makes you feel any better, I'm fighting with a pipe fitting the previous owner installed in the side of the driver's side head. No nut to grab onto, just threads. Just ordered a set of pipe extractors off ebay to see if it'll do the job a propane torch and vice grips couldn't.
Old Jun 1, 2009 | 06:40 PM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
Re: Intake Bolt
If worse comes to worse, you can grind the head off. You should be able to get the intake off then. Then you could put two nuts on it and jam them together. Or, drill it out and use an extractor (ez-out). Or maybe you could grab it with vise grips and twist it out if it's not siezed too badly.
Once the intake is off, you could also square up the shank by grinding the threads down and use a 1/4" wrench on it. Last resort weld something to it. Absolute final result, grind it down flush with the deck and drill it all the way out. Tap and repair with heli-coil. Good luck.
Old Jun 2, 2009 | 12:58 AM
cooter26's Avatar
Car: 83 Camaro
Engine: 383
Axle/Gears: 4th gen 10 bolt 3:42 POSI
Re: Intake Bolt
A cople of other things that werent mentioned.
Try a dual patern wrench (one that fits metric and standard) or a flare nut wrench.
Heat up the bolt with a propane torch and drip some candle wax along side it. The heat should wick the wax into the threads.
Good luck
Old Jun 2, 2009 | 01:14 AM
gurkgurkgurk's Avatar
Car: 86 Camaro iroc-z28
Axle/Gears: 3.42 Posi
Re: Intake Bolt
ive seen the wax trick, but we used it on oil galley plugs, and we used an acetylene torch. it made quick work of them though. dont see why propane wouldnt work
Old Jun 2, 2009 | 01:16 AM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Re: Intake Bolt
I couldn't get a few intake bolts out myself (the ones that go in the coolant passages). I tried PB Blaster, heat, candle wax...etc Nothing worked. I'm not sure what you call them, but my dad had these sockets that get rounded out bolts loose. It was a socket with these razor sharp teeth in it. We put it over the bolt, hammered it on, got a wrench on there and they came right out.
Old Jun 2, 2009 | 01:35 PM
Car: 89' Camaro
Engine: 350 SBC
Re: Intake Bolt
I want to thank everyone for there help
I have a buddy of mine thats going to come weld a allen wrench on it next weekend
Terrell351
Jun 13, 2021 01:13 PM
deracer
Apr 11, 2016 12:04 AM
LT1Formula
20
Nov 14, 2015 12:02 AM
theurge
Aug 21, 2015 12:46 PM
