Bench Testing Rebuilt engine
Old Jun 2, 2009 | 12:57 PM
gclay's Avatar
I am finishing rebuilding a TPI engine. I would like to "Start it up" on a bench before installing it into the car.
I am 57 years old and in years past, when cars had carburetors and distributors, this was not difficult, but I fear this may be difficult, because of the ECM, fuel injection (Pressurized fuel pump in gas tank) etc.
Does anybody have any experience doing this?
Is there a straightforward way of doing it?
AtDhVaAnNkCsE
George
Old Jun 2, 2009 | 01:01 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Bench Testing Rebuilt engine
If you build a decicated stand, but I think it'd be easier to r&r the engine 3 times than buy an extra fuel pump, fuel lines, and transfer over the wiring harness, battery, computer, radiator with fan and hoses, et cetera.
Old Jun 2, 2009 | 04:02 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I agree. I've done this with my carbed engine, and i've customized a stand for it, but for an FI engine it's MUCH harder. I'd just stick it in the car and hope for the best
Old Jun 2, 2009 | 04:17 PM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
There is no reason you can't start it with a conventional carb and hei dist, you'll just have to swap the intake and rig up some way to get fuel to the carb.
Old Jun 2, 2009 | 05:23 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You don't even have to put mount bolts in the center two intake bolt holes if you don't want to. Since they're at a different angle (most likely) than the old-school carb intakes, that's one hassle it doesn't make sense to go through just for a short test.
Old Jun 3, 2009 | 08:32 AM
gclay's Avatar
Thank you
As usual, I get a lot of wisdom from the experience of the members of this board.
I guess I'll have to install it and hope I don't have to remove it for some stupid mistake.
Aint progress great.
Regards,
George
Old Jun 3, 2009 | 09:40 AM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
I must've been asleep, I now agree with afremont and five7kid.
Reddeath210
Oct 6, 2015 08:20 AM
backtothe80s
Sep 5, 2015 12:39 AM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
