Dyno Disappointment and wont stay started
Old Jun 3, 2009 | 09:24 AM
89formula350b2l's Avatar
Car: 92 Camaro
Engine: Dart SHP 406 HSR, LE heads
Transmission: Performabuilt Level 2, Vig 3200
Axle/Gears: S60 373
Had Lloyd Elliot Custom grind a cam for me that peaked around 6000rpms and would make around 400rwhp. With my old xr276hr cam i put out around 330rwhp @ 5300 and 340rwtq.
New dyno showed before 217 rwhp @ 4600 rpms and 240 rwtq @4600 rpms.
Now the car has to be revved to about 1500-1700 rpms to stay started. It shut off on the drive home from the dyno place too. I am getting very very disappointed with this car and i have no idea what could be wrong. Injectors were 30lbs Ford Motorsport and new ones are 36lbs. Retainers, springs ect were also replaced when cam was installed. Ideas fellas?
Old Jun 3, 2009 | 10:27 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Dyno Disappointment and wont stay started
If I understand you correctly, you have a 350 bored 40 and stroked to a 385, you have AFR 195cc heads, and an unmodified HSR. I assume headers and single 3" exhaust. You decided the cam was the next step. If I have it correctly, then I suggest you reinstall the XE276HR, have the HSR Extrude-honed, and contact Mufflex for one of their 3.5" exhaust systems. Also, if your headers are 1.625", you've reached the point of needing 1.75", such as SLP for shorties or Hooker SuperComps for long tubes. That still won't get you to your goal, so did you get thr 276 with 110 lobe sep, or the 276 with 112? If you got the 110, I suggest moving up to a custom ground 282 on a 112. If you got the 112, I suggest a 282 on a 114. This should get you really close to your goal.
Old Jun 3, 2009 | 11:02 AM
Car: 92 Camaro
Axle/Gears: S60 373
So instead of finding out the problem, you say get rid of the custom cam?
Old Jun 3, 2009 | 11:04 AM
Car: 92 Camaro
Axle/Gears: S60 373
and ive seen plenty of cars in the 10's with 1 5/8 Hedman longtube headers (which i have).....everybody that CAN port the HSR says it isnt worth the $.
Old Jun 3, 2009 | 11:14 AM
dellman83Z's Avatar
Car: 87 monte aerocoupe
Engine: 383 HSR w/ novi 2000
Transmission: Built 4l80e circle d converter
Axle/Gears: Currie 9" 3.89 gears
There's a lot of things that could be wrong. Is the timing set right on the gears, maybe off a tooth. How about ecm programmed for the different cam.
Old Jun 3, 2009 | 01:05 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
There's a big difference between rookie porting and Extrude Honing.
Old Jun 3, 2009 | 11:42 PM
Black Z28's Avatar
Car: '88 Iroc-Z z28 Camaro
Engine: Carb 355
Transmission: t5 5-speed
Axle/Gears: 4.11
Obviously its a tune port only with a hsr which means it have an ecm, my question to u is that, are u running a stock ecm with a stock prom? if so you're in the same situation im in only im getting mine tuned or for our cars a chip installed. if u dont have something done to your ecm to upgrade it then you're choking your motor and the stock settings are being put to your wheels instead of your 383
Old Jun 4, 2009 | 01:37 AM
Car: 92 Camaro
Axle/Gears: S60 373
Computer was reconigured via tune.
Old Jun 4, 2009 | 10:54 PM
Black Z28's Avatar
Engine: Carb 355
Axle/Gears: 4.11
Huh, well im stoked hook a computer up to the thing and let it rock and see wat the results are
Old Jun 5, 2009 | 06:20 AM
Car: 92 Camaro
Axle/Gears: S60 373
Those were results after the tune......but it did throw a code 51 (which ever one was the PROM error one)
Old Jun 5, 2009 | 08:10 AM
bjankuski's Avatar
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
What are the specifications on the new cam? When you had it dynoed did you get a printout of the AFR, it could be that your tune is way off. What I find strange is that HP and tq both peaked at 4600 RPM, did you stop the pull? Typically the HP will peak 1000 RPM higher then the torque.
I believe you have some sort of mechanical/electrical issue that is causing your problems (coil bind, computer issue). You should not have lost that much power with just a cam change.
Old Jun 5, 2009 | 08:18 AM
LoudmouthSS's Avatar
Car: 1991 Z28
Engine: SBC
well there is your problem right there...its obviously a tuning issue then. Re burn the tune to another chip and see if that fixes it. If not check and make sure all your connections are good and clean.
Old Jun 5, 2009 | 10:16 AM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
You wouldn't've lost 100 rwhp from a cam with the tune you had if the guy had any clue how to spec a cam for injection. He probably added quite a bit of overlap, which you really neither need nor want. No more than 10 degrees at 0.050" for injection, but if you went carbureted, you'd do better with 16-20 degrees at 0.050". By sticking to this guideline, I've never had an unhappy customer with a 3.750"-stroke-SBC.
Old Jun 5, 2009 | 10:23 PM
Car: 92 Camaro
Axle/Gears: S60 373
I dont want to give the specs out on my cam, bc Lloyd is tight lipped about the cam, however, i can say that it isnt more than 10 degrees overlap.
Lloyd is pretty good....alot of guys are running his cams
Edit: Could a rocker arm (or arms) out of adjustment cause the lack of power and peaking at such a low RPM?
Old Jun 8, 2009 | 08:16 AM
Car: 92 Camaro
Axle/Gears: S60 373
ttt
Old Jun 11, 2009 | 07:17 AM
Car: 92 Camaro
Axle/Gears: S60 373
Now it wont start at all.....I'm gonna shoot it!!
Ghettobird52
Jul 5, 2024 11:18 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
perZ
Aug 21, 2015 05:51 PM
EFR2000
Aug 18, 2015 08:54 PM
perZ
Aug 15, 2015 01:17 PM
