Advance wire??? 1987 GTA (5.7 TPI Auto)
Old Jun 3, 2009 | 04:04 PM
Dany89's Avatar
does anyone know what is the advance wire??? i took my car to a mechanic and was told to fix that, the mechanic told is a wire that hooks uo tot he distribuator. it s a light brown wire that runs along the passenger side and was told that hooks up to the distribuator.
Old Jun 3, 2009 | 07:40 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Often referred to as the "EST" or "ESC" wire. It's what sends the signal to the computer from the distributor so the computer can make timing decisions. It's a tan wire with a connector in the area of the heater/AC box.
Old Jun 3, 2009 | 08:18 PM
Dany89's Avatar
re: Advance wire??? 1987 GTA (5.7 TPI Auto)
if this would not be working what would be happenig to my car??? i followed the cable and its connected right behind the distribuator it conects to a thing that kind of looks like a gasonline filter but it has a wire plug is this the one???
Old Jun 4, 2009 | 01:20 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
FYI
In my book to set the timing it states:
Disconnect SET TIMING connector (tan/black wire) located in harness close to distributor. DO NOT disconnect 4 wire connector at distributor.
Distributor 4-pin connector:
  1. EST; Pin D
  2. Distributor reference; Pin C
  3. Bypass; Pin B
  4. Distributor ground; Pin A
All 4 wires connect to the ECM.
The Bypass is the only wire that has a quick disconnect which is the SET TIMING connector mentioned above.
But, the connector itself is where Five7kid said.
The ESC module should never be disconnected to set the timing.
Old Jun 4, 2009 | 01:41 AM
five7kid's Avatar
That sounds like the oil pressure gauge sending unit.
Old Jun 4, 2009 | 11:46 AM
Dany89's Avatar
Re: Advance wire??? 1987 GTA (5.7 TPI Auto)
http://i239.photobucket.com/albums/f...o/DSCN3509.jpg
http://i239.photobucket.com/albums/f...o/DSCN3508.jpg
is these the same wire??? when i disconect the one by the AC my car runs alright but when it is connecte it wont rev more than 2500 and sometimes turn off they told me it was the advance but i really dont know what that is or how to fix it
Old Jun 4, 2009 | 07:15 PM
five7kid's Avatar
The first wire is the one you disconnect to set the timing.
The second one is the oil pressure gauge sending unit.
They are not the same thing.
As pictured, the advance wire is not fully engaged. You should get an SES light if the engine is run without the wire connected. It looks like the connector clip is broken, perhaps that's what the mechanic thought should be fixed.
If not connected, the engine will run but you won't get proper timing advance. Power will be down.
Do you know where the timing is set at? Do you know if it was set properly? If the timing was set with the wire connected, you wouldn't have enough advance. The engine might idle, but it wouldn't have any power.
Old Jun 5, 2009 | 02:44 AM
Dany89's Avatar
so if i were to fix the timeing i would 1st disconect the advance wire and set the timimg right, then connect the wire back on right????
Why does my car run well without the advance wire connected??? if i do connect the wire the engine wont rev, for example if i connect it and put my car on D when i start driving the engine will rev only to about ~2000 even if i floor the gas. and when in P if i accelarate it will rev up to about
~5500+ but sort of startle
Old Jun 5, 2009 | 02:46 AM
Dany89's Avatar
so if i were to fix the timing i would 1st disconect the advance wire and set the timimg correct, then connect the wire back on right????
~5500+ startling and sometimes even when flooring the gas the revs will fall and car will turn off
Old Jun 5, 2009 | 08:20 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
After you set base timing, turn the car off and disconnect the negative battery cable and plug that cable back in. When the ECM resets it might fix whatever it is you';re dealing with.
Old Jun 5, 2009 | 12:44 PM
five7kid's Avatar
Most likely your timing isn't set properly.
Disconnect that tan/black stripe wire. Start the engine. With the engine at idle, set the timing with a timing light to where the timing is supposed to be. Shut off the engine. Reconnect the wire.
Old Jun 13, 2009 | 12:10 AM
Dany89's Avatar
whats the proper timeing for the 87 TPI 5.7 engine
Old Jun 15, 2009 | 02:33 PM
screeminchicken's Avatar
6 deg TDC
jaridjohn
Jul 8, 2024 03:49 PM
1nastygta
Oct 28, 2015 08:51 PM
beachrodder
Aug 25, 2015 08:05 AM
jharrison5
Aug 19, 2015 05:53 PM
marcusaw
Aug 10, 2015 08:13 AM
