Code 53 and Strange Accelleration Issues
Old Jun 3, 2009 | 07:23 PM
bluerocz's Avatar
Car: 1986 Z28
Engine: 305 4bbl LG4
Transmission: AOD
delete
Old Jun 4, 2009 | 06:12 PM
bluerocz's Avatar
Car: 1986 Z28
Transmission: AOD
Re: Code 53 and Strange Accelleration Issues
delete
Old Jun 4, 2009 | 07:28 PM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
My service manual (90) says a code 53 is system over voltage. It means the voltage detected at the IGN input of the ECM is greater than 17.1 V for 2 seconds. That would be your charging system over doing it.
Old Jun 4, 2009 | 09:59 PM
bluerocz's Avatar
Car: 1986 Z28
Transmission: AOD
delete
Old Jun 21, 2009 | 12:35 PM
da_jester's Avatar
Car: 1992 camaro rs
did you ever figure this out ive got the same code my 92 305tbi?
Old Jun 21, 2009 | 01:06 PM
Doom86's Avatar
Car: '86 Z28, '91 RS
Engine: 305ci, 305ci
Transmission: TH200c (no kidding), TH700r4
Axle/Gears: 2.73, 2.73
blurocz i have the same exact problem, the stumbling at 2kish, and getting code 53 on long cruises.
I do not have an EGR valve provision on my after-market intake manifold. The sensor for it is still hooked up and sending a signal to the ECM. From what i have read the stumbling is caused by the computer adjusting the timing to compensate for the EGR and since it isn't there its excessive timing.
I would check the vacuum lines going from the EGR solenoid to the valve because it sounds like your solenoid isn't getting vacuum from the valve. And if those check out check the EGR for proper function by pressing up on the diaphragm (it's on the underside of the valve) at idle and seeing if it effects the idle.
Old Jun 21, 2009 | 05:24 PM
bluerocz's Avatar
Car: 1986 Z28
Transmission: AOD
delete
Old Jun 21, 2009 | 05:34 PM
Doom86's Avatar
Did you try to press the EGR diaphragm while at idle? it shouldn't be hard to press in at all. If you have to really put pressure on it i bet the valve is shot and not sending and pressure at all to the solenoid.
The vacuum lines should be easy to check since there is only 1 going from the solenoid to the valve.
Just from what you described (the stumble) and you are getting the same code and symptom as me, and same year car/ecm, I'd put money on that valve is too stiff and not functional.
Old Jun 22, 2009 | 12:24 PM
bluerocz's Avatar
Car: 1986 Z28
Transmission: AOD
delete
Old Aug 27, 2009 | 05:06 PM
shanewbenson's Avatar
Car: 1992 RS
Engine: 305 TBI
Transmission: IROC 700R4
i just hollowed my cat and got a code 53 cause of exhaust readings. maybe your issue is in the o2 sensor or something
Cornholio7979
Sep 20, 2018 02:31 AM
red90IROCls1
Aug 25, 2015 06:56 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
mizz0313
Aug 12, 2015 06:45 AM
