Running fine during day but at nite ???
Old Jun 3, 2009 | 10:20 PM
Black Z28's Avatar
Car: '88 Iroc-Z z28 Camaro
Engine: Carb 355
Transmission: t5 5-speed
Axle/Gears: 4.11
I got an '88 Iroc with a 383 stroker in it with stock ecm and prom with a 5 speed. For some odd reason during the day it'll run fine and I can have it wide open throttle and hit high speed with high rpm's. However during the nite when i try to reach high rpm's and high speed's, the car will spitter and sputter and i can go full throttle. I completely ran out of ideas, i changed spark plugs, opened up the gap on them, the icm is new and good working, wires are getting at spark. i jus dont know wat it is. please help me, i trying racing some mustangs and this happens. Thank you for any help
Old Jun 3, 2009 | 10:45 PM
brians88gta's Avatar
Car: 88 gta
Engine: 350 HSR
Axle/Gears: 3:27 borg warner 9 bolt
Re: Running fine during day but at nite ???
do u have a mass air sensor, if so u can clean them. i have to clean mine monthly or it gets a stutter especialy at night
Old Jun 3, 2009 | 10:49 PM
Black Z28's Avatar
Engine: Carb 355
Axle/Gears: 4.11
how do i clean it because i descreened mine
QuickStyle's Avatar
Car: 91 Z28
Engine: 383 SuperRam
Transmission: ProBuilt 700r4
Axle/Gears: G92 3.23
probably has to do with the lower outside temps at night. get it tuned to run properly at all temps, get some datalogs and post it up in the diy prom board.
Old Jun 3, 2009 | 11:35 PM
Black Z28's Avatar
Engine: Carb 355
Axle/Gears: 4.11
ok, im gonna have my buddy do that when he attepmts to tune it this weekend. hes got the labtop, the chip burner, everything that I need to burn my own chip. its come pretty neat stuff of wat he can do on this lil labtop
Old Jun 3, 2009 | 11:53 PM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
Maybe low voltage on the ignition when the lights are on?
Old Jun 3, 2009 | 11:56 PM
Black Z28's Avatar
Engine: Carb 355
Axle/Gears: 4.11
Nah belt it tightened to the max and the alternator charges jus fine
theshackle
Mar 5, 2017 06:37 PM
apo_bailon15
Mar 28, 2016 05:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Kaweh
Aug 9, 2015 02:54 PM
Sherpajames
Aug 7, 2015 06:56 PM
