83 LG4 heads vs 86 LG4 heads
Old Jun 4, 2009 | 09:00 PM
Josh R's Avatar
Car: Iroc
Engine: 350 4-bolt
Transmission: T5 non-W/C
Axle/Gears: 3.27 Open
Are there any differences between 83 and 86 LG4 heads? I know that the motors compression ratios are different because of the pistons but are the heads the same?
Old Jun 5, 2009 | 11:02 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: 83 LG4 heads vs 86 LG4 heads
pop the valve covers and check the casting numbers. They should all be 416s.
Old Jun 5, 2009 | 06:49 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
difference in compression would be pistons.
some later LG4 are higher compression according to GM specs
all the early ones are less
Old Jun 5, 2009 | 08:01 PM
Damon's Avatar
Should be. Wasn't until 87 that they started using the centerbolt valve cover heads.
You're correct- the compression ratio differences over the years were due to different pistons being used.
Old Jun 6, 2009 | 02:43 PM
Josh R's Avatar
Car: Iroc
Engine: 350 4-bolt
ok ill check the casting number. And yeah i think in 85 they uped the cp to 9.5 where as before it was 8.5 or something. Just making sure i wasnt lowering my compression by changing heads. Thanks.
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
92projectcamaro
Jan 18, 2016 08:00 AM
New2Chevy
Sep 28, 2015 12:35 AM
z28guy134
Sep 1, 2015 11:50 PM
