Need help identifying a part
Old Jun 8, 2009 | 03:16 PM
majobis's Avatar
Car: 1987 IROC Z w/T-Tops
Transmission: Automatic
Axle/Gears: G92
Hi All,
I am missing a small part and need the name of it so I can look for it.
I have an 87 Iroc w/a 305 T.P.I.
Where the top portion of the hard plastic piece (attached to the 2 air filters) meets the flexible hose of the Bosch unit, I am missing the piece that attaches the two. There is a clamp there, but the clamp has nothing to bite/attach to and the housing can be easily moved.
Included is a picture (not of my car) of a similar engine with the part in question within the circle.
Thanks in advance!
Old Jun 8, 2009 | 04:00 PM
TPeye's Avatar
Car: 1992 Camaro Z28
Engine: 350ci
Re: Need help identifying a part
The hard plastic Y shaped piece that covers the two air filters slips directly in to the rubber intake bellows. Maybe your Y shaped piece is broken off where it necks down to connect to the bellows. A picture of your car would make this easier.
Old Jun 8, 2009 | 06:50 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Not on an 87, the MAF sensor is there.
Old Jun 8, 2009 | 07:03 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
The plastic piece that covers the twin air filters is called the flow lid, its large and Y-shaped, always black in color. Since you have an '87 TPI, you have a MAF car (unless its been altered). The sensor that connects to the flow lid is the MAF (Mass Air Flow). To connect the MAF to the air (flow) lid, is a round metal band with teeth. Are you talking about this metal band? If you are, just use tape or go to a junk yard.
BTW: your pic is of a MAP car, not MAF, so its mis-leading.
LT1Formula
20
Nov 14, 2015 12:02 AM
Linson
Aug 21, 2015 02:12 PM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
