87 IROC Tranny lines
Old Jun 8, 2009 | 03:27 PM
87_Injected's Avatar
Car: 2010 2LT RS
I need to replace my tranny lines due to a leak. There is rust forming on the lines and I would like to know where to get replacement stock parts? Or better yet..stainless steel lines. I was told by the oil change shop that they cannot be found since they aren't made anymore. Would I need to have them custom made?
Old Jun 8, 2009 | 06:53 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 87 IROC Tranny lines
Try Fine Lines or Classic Tube. There never were direct replacements available from GM, they were always serviced with bulk tubing bent to fit.
Old Jun 8, 2009 | 07:28 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
What I did was to buy plenty of steel braided hose line. I cut the factory lines about 6" from the tranny fittings and started the braided lines there with a clamp. At the front end, I installed a tranny cooler and ran the braided lines straight to the cooler. The cooler is mounted in front of the radiator.
Old Jun 9, 2009 | 08:25 AM
Car: 2010 2LT RS
The fine lines website is coming up as a drapery/curtain website Do you have the exact website for this? As for Classic Tubes.. I have to call in since their website is under maintenance.
Old Jun 9, 2009 | 09:14 AM
Car: 2010 2LT RS
I have to ask though. What size are my factory transmission lines? I need to know this for when I order from Totally Stainless since they have it in stock. Classic Tubes will take several weeks to make.
Old Jun 9, 2009 | 04:43 PM
Car: 2010 2LT RS
Anyone?
Old Jun 10, 2009 | 03:17 PM
Car: 2010 2LT RS
TTT
Old Jun 11, 2009 | 07:33 AM
Car: 2010 2LT RS
TTT
Old Jun 11, 2009 | 07:42 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
I replaced mine with braided hoses and barb fittings. Makes it easy to route and is shielded from my LT headers.
Old Jun 11, 2009 | 06:49 PM
Car: 2010 2LT RS
I appreciate some of the responses, however I really need to know what size are these transmission lines? So many views and not many responded. I am ready to place an order but need to know the size. Thanks.
Old Jun 11, 2009 | 07:20 PM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
I beleive these were the lines I bought. http://www.summitracing.com/parts/SUM-230606/
I bought two lengths and got the barb fittings to match the threads on the trans at the local parts store. I used the wide screw clamps with no leaks. You can buy the AN fittings or the push lock fiittings but they will cost more $$$.
The fittings I used were like these.http://www.summitracing.com/parts/TRD-2269/
Im not sure on the fitting size on the 700r4 or the radiator. It is either3/8 or 5/16.
You might even get by with 4ft lenghts. http://www.summitracing.com/parts/MRG-S46/
Old Jun 11, 2009 | 09:54 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
5/16"
A tape measure would have saved you a few days of waiting.
Thornburg
Aug 25, 2015 01:46 AM
spaigo
Aug 21, 2015 07:46 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
mustangman65_79
Aug 11, 2015 03:17 PM
