breaks
Old Jun 9, 2009 | 12:01 PM
hpmustangs's Avatar
Car: 89 trans am
Engine: 350 tpi
Transmission: 700r4 not for long if i can help it
breaks
i have a 89 firebird all stock and im having to put the breaks to the floor to get her to slow theres no leaks in the break system i changed the pads and roters thinking that would help then i bleed the breaks thinking that would help and i have new pads for the drums hoping that will help but if that dosent what could be the problem
Old Jun 9, 2009 | 12:02 PM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
Re: breaks
The hoses.
Old Jun 9, 2009 | 12:12 PM
hpmustangs's Avatar
Car: 89 trans am
Engine: 350 tpi
Re: breaks
i checked and there arnt eny leaks could one be bulging when i hit the breaks
Old Jun 9, 2009 | 12:16 PM
kkingsrulee's Avatar
Car: 1990 Camaro RS
Engine: V8 305 TBI
Transmission: W/C T5
Axle/Gears: 3.08
Re: breaks
Replacing the shoes will not help because shoes are self adjusting.
Bleed the brakes, there could be air in the system which would create a spongy feeling in the pedal and since air is compressible it will create a longer pedal.
Check all of the rubber brake lines by the wheels.
Hope this helps.
Old Jun 9, 2009 | 12:27 PM
hpmustangs's Avatar
Car: 89 trans am
Engine: 350 tpi
Re: breaks
if there is air somewhere near the master cylinder about how many times should i bleed them before i get the air out
Old Jun 9, 2009 | 05:15 PM
Car: 1990 Camaro RS
Engine: V8 305 TBI
Axle/Gears: 3.08
Re: breaks
Well you probably will have to bleed every wheel if you believe there's been air in the system for a while. Bleed every caliper one at a time until fresh fluid is all that will bleed out.
UltRoadWarrior9
Apr 28, 2020 10:39 PM
apie2546
Oct 16, 2016 02:24 PM
ZekeThorpe
Theoretical and Street Racing
35
Oct 7, 2015 07:30 PM
sjorgens
Oct 1, 2015 07:54 PM
mfp189
Sep 27, 2015 09:25 AM
