Vacuum Line mess-82 TA
Old Jun 11, 2009 | 10:38 AM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
I have a 82 LG4 carb engine in my 86. I need to route all of the vacuum lines properly. Right now it is a mess. I just removed all of the emissions stuff.
I have the diagram of how the hoses should be routed. However I need to identify certain parts so I can route. The diagram still does not really show me what these look like;
EGR Solenoid
EGR
EFE
EFE TVS
Purge TVS
Air MGMT Valve
Check Valve
If you have pics of these can you post them? Thanks....
Old Jun 11, 2009 | 02:30 PM
Axle/Gears: Posi
Re: Vacuum Line mess-82 TA
Bump...I really need help on this today...thanks
Old Jun 11, 2009 | 09:50 PM
Mr Froman's Avatar
Car: 1990 Firebird Formula
Engine: LB9 - 5.0 TPI
Axle/Gears: 2.73, LSD
I'm with him here. I have a 90 formula (TPI) and need to know what the EGR Solenoid looks like and where I can pick up a new one.
Old Jun 14, 2009 | 01:07 AM
82CrossFire Z28's Avatar
Car: 82 Camaro Z28, 88 IROC-Z
Engine: 5.0L TBI., 5.7TPI
Transmission: Auto TH200C, 700R4
Axle/Gears: 3.23 posi, ones that rotate!
niterider
I have the 1982 Camaro Factory Assembly manual. I will try to scan and post some diagrams for the 82 LG4 engine. There probably are 10 -15 diagrams, as different systems and hoses are shown in different area of the book.
The EGR value should mount on a bracket that is mounted to the intake on the passenger side, between the EGR valve and the Carb.
I think the hose in your third picture is for the EFE valve. The EFE mounts on the exhaust pipe just below where the exhaust manifold connects on the passenger side. There is supposed to be a metal pipe from the EFE up to the area where that hose is. The digrams may help to clear some of this up.
The local Camaro club is having a picnic tommrow, so I will be busy with that fucntion all day. I will try to get some of the diagrams scanned and posted Sunday evening.
Dave
Old Jun 15, 2009 | 01:05 AM
Axle/Gears: Posi
Originally Posted by 82CrossFire Z28
niterider
Dave
Thanks. My problem is I have a 82 engine in a 86 body. I think I have it close but I am still guessing without pics. Thanks in advance for the scaned pics.
Old Jun 16, 2009 | 11:18 PM
86NiteRider
I am not sure how many posts this will take. I mad pdf files because they were much smaller in size than scanning the diagrams.
Note that most of the options are noted like this....
&C60 = Air Conditioning
&K35 = Cruise Control
&MV9 = Auto Transmition
&MX1 = Some pieces or mounting brackets required with the MV9
&NM8 = Emission Controls, Recalibrated ( I am not sure what this means, as one or two of the diagrams also has an &NM4 which will only give an error on the RPO decoder)
I suggest you print all the pdf files out. They are all 8.5 by 11 and usually there are only two pages per file. After printing them out, study them with the connection diagram you posted and your car. Hopefully you will be able to figure it out.
Dave
File Type: pdf
File Type: pdf
File Type: pdf
Old Jun 16, 2009 | 11:20 PM
Here are a few more....
File Type: pdf
File Type: pdf
File Type: pdf
Old Jun 16, 2009 | 11:22 PM
And the last three. If you have any questions, let me know and I will try to answer them.
Dave
File Type: pdf
File Type: pdf
Old Jun 19, 2009 | 10:00 AM
gotay5's Avatar
1971 CHEVELLE 307 2BBL
I NEED VACUUM HOSE DIAGRAM FOR 1971 CHEVELLE 307 2BBL
THANX: GOTAY5
Old Jun 19, 2009 | 02:57 PM
Axle/Gears: Posi
86NiteRider
Dave
Thanks..this will help a lot.
Old Jun 19, 2009 | 09:49 PM
THANX: GOTAY5
This is a thridgen Camaro board. I suggest you find a Chevelle board and ask there. Try Google
Dave
gta892000
Aug 11, 2019 11:16 AM
camarohelp
Sep 12, 2015 05:45 PM
Doobie52
Sep 11, 2015 06:19 PM
IROCtometal
Sep 9, 2015 10:01 AM
snakeshooter
Sep 7, 2015 11:13 AM
