305 tpi running too rich
Old Jun 19, 2009 | 01:22 PM
Jasper8391's Avatar
Car: 71 Chevelle
Engine: 85 305 TPI map
Transmission: 88 700r4
Hey, i just swapped an '85 305 tpi into my '71 chevelle. I cut out all EGR and A/C from the harness, updated the ECM and everything else to run with a '165 ECM, and have a stock prom from an '86 305 tpi. I started it up, and it seems to idle alright, but as soon as i push the throttle, the engine is getting waayyyy too much gas, and it bogs down instantly and sometimes backfires. Before i put the engine in i put a penny in the regulator because i heard it was a good cheap mod. I just took the penny out and it seems to run even richer.
Can someone please help?
Old Jun 19, 2009 | 11:22 PM
lunaticinaZ's Avatar
Car: 1991 Black Z28 G92
Engine: 350 for now
Transmission: wc t5
Axle/Gears: factory 3:42
Re: 305 tpi running too rich
check the throttle position sensor. mine was bad and my car would start and then die unless i kept my foot on the gas but even then it would run for a few then bogg down and die. i replaced the tps and it ran fine.
BlueIroc-Z
Jun 9, 2019 03:22 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
1nastygta
Oct 28, 2015 08:51 PM
st.evel07
Aug 13, 2015 06:15 PM
drathaar907
Aug 6, 2015 04:20 PM
