Mass air flow????
Old Jun 11, 2009 | 01:11 PM
Dany89's Avatar
Mass air flow????
Will eliminating the mass air flow sensor affect the engine in any way??? im planing on just running a cold air intake to the TPI throttle.
kind of like this one http://cgi.ebay.com/ebaymotors/90-92...530136002r7290 but w/out the mass air flow
Old Jun 11, 2009 | 10:18 PM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
Re: Mass air flow????
No unfortunately you cannot eliminate the MAF sensor as the way your system works is the MAF sensor directly measures the air comming into the motor and useing that information as well as information from other sensors calculats how much fuel to inject. That being said you can swap to a MAP style system that dosnt use a MAF sensor but that would be more trouble than its worth if all you want to do is eliminate the MAF senors.
Old Jun 15, 2009 | 04:15 PM
Chuck's Avatar
If you get an error code reporting trouble with the MAS,
does that usually mean it needs to be replaced?
Old Jun 16, 2009 | 11:14 AM
MTXaudioSYSTM's Avatar
Car: 90 formula
Transmission: auto
pretty sure somebody swapped mine to maps from maf.
i have k/n intake. i wouldn't suggest buying one for a 3rd gen.
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
scotrans am
Sep 5, 2015 04:26 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
