1988 TPI 350 I-ROC-Z camaro preformace problem
Old Jun 12, 2009 | 06:47 AM
Granty4510's Avatar
hi mates need some help, when i take the car out early in the morning,
it goes like a machine.
but when it warms up it loses so much prefomace any help mates? thanks
Old Jun 13, 2009 | 10:31 PM
nghanie's Avatar
Car: 86' Z-28 Iroc Camaro
Engine: V8 5.0
Transmission: Automatic
Re: 1988 TPI 350 I-ROC-Z camaro preformace problem
hows the cooling system? dose the temperature gage go up real fast?
Old Jun 14, 2009 | 01:13 AM
Granty4510's Avatar
i think the radiator should be relplaced just found a leak?
would you know what colour TPI badge goes on the back of an black 1988 IROC-Z camaro thanks mate?
Old Jun 14, 2009 | 10:00 AM
nghanie's Avatar
Engine: V8 5.0
not to sure. you can try rplaceing the radiator . idk how much money that will be
Old Jun 14, 2009 | 03:02 PM
Black Z28's Avatar
Car: '88 Iroc-Z z28 Camaro
Engine: Carb 355
Transmission: t5 5-speed
Axle/Gears: 4.11
Trace the leak and see if its coming from the radiator, it could be the radiator or the water pump, if your gonna chanhge the water pump then you minus well change the thermo same goes for replacing the radiator
jhawkeye
May 25, 2022 06:33 PM
Vintageracer
Jan 10, 2020 05:33 PM
theshackle
Mar 5, 2017 06:37 PM
st.evel07
Aug 13, 2015 06:15 PM
gta power
Aug 13, 2015 06:15 AM
