full bolt ons head options
Car: 1987 iroc z
Engine: 350tpi
Axle/Gears: 342
so i found out my heads are the reason for all my problems. i dont want to put a cam in my car as its my daily driver but i have a full intake meaning everythings aftermarket and full exhaust. what options for heads do i have i want something that will keep the car running smooth and maybe add a few horses. give me some part numbers and prices please.
Transmission: 4L80E/4L80E
What heads do you have that are causing all of these unnamed problems?
Car: 1987 iroc z
Engine: 350tpi
Axle/Gears: 342
Re: full bolt ons head options
i have the stock l98 cast iron heads. the valve guides are bad and are in need of a rebuild so i was wondering if while there off i should go another route.
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
I would definitely go with aluminum heads of some kind. You might consider Corvette L98 aluminum heads, Or go the Summit Racing for their alu heads or Patriot Perforamnce.
Also, new valve springs are in order, so purchase a pair of heads that are assembled.
Use the 1010 Felpro head gaskets for any of the above aluminum heads.
If you aren't changing the cam, just have the stock iron heads worked over.
Car: 1987 iroc z
Engine: 350tpi
Axle/Gears: 342
i wanted to buy new or rreman so i dont have that much downtime on the car as its my only car. what options do i have and will i see much gain without changing my cam. please give some part numbers if possible
355tpipickup
Aug 25, 2015 12:54 AM
