battery drained after 5-10 minutes or so of running
Old Jun 15, 2009 | 08:34 PM
dexint's Avatar
im having trouble just got an 86 trans am with tpi 5.0l fuel injected and after i let it run for about 5-10 minutes it kills the battery i had the alternator tested and it checked out to be ok at autozone, but i did find a positive wire that seems to go to the starter that was split at a solderless crimp and the wire was just hanging apart, its to dark out now to check that, but do u think that would cause my battery problem im going to hook it up tommorrow after the battery charges any input is greatly appreciated thanks
Old Jun 15, 2009 | 08:38 PM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
Re: battery drained after 5-10 minutes or so of running
you reversed the lines - positive to negative. easy to do.
Old Jun 15, 2009 | 08:46 PM
dexint's Avatar
what do u mean reversed the lines?
Old Jun 16, 2009 | 09:32 AM
plasmeh's Avatar
Car: 1986 IROC-Z
Engine: 360cu @ 10.5:1
Transmission: T56 - Pro 5.0
Axle/Gears: 4.10 - Zexel Torsen - Moser Axles
Appreciate this input dork.
Old Jun 16, 2009 | 04:50 PM
KWIK84's Avatar
Car: 1984 Z28
Engine: Alky 360
Transmission: TH400, Freakshow 9.5"
Axle/Gears: 9" 4.71
More than likely that wire is the culrpit, the large terminal on the starter is where GM put the "junction" for the charge wire to connect to the battery. IIRC it is a 10ga wire.
Frozer!!!
Jan 19, 2024 04:55 PM
apo_bailon15
Mar 28, 2016 05:20 AM
jbd1969
Aug 17, 2015 07:06 PM
djmarch
Aug 9, 2015 05:27 PM
