Lubricant
Old Jun 17, 2009 | 03:48 PM
mesterious's Avatar
Lubricant
I need to know what kind of lubricant/brand i should use for bearings, main journals, cylinders, camshaft lobes (im sure lube comes with the camshaft though), ect.... and also its going to be a good year before the engine gets cranked if that changes anything..
Old Jun 17, 2009 | 05:43 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Crankshaft lobes?
Crank journals, bearings - assembly lube (take your pick).
Pistons, rings, cylinders - engine oil.
Camshaft lobes, bottoms of lifters - ARP thread lube.
Lifter bores - engine oil.
Old Jun 17, 2009 | 07:59 PM
mesterious's Avatar
Re: Lubricant
Originally Posted by five7kid
Crankshaft lobes?
k thanks i ment camshaft lobe haha.. but do i just put the engine oil around the piston then dip the rings in and put some lightly around the cylinders?
Old Jun 17, 2009 | 08:41 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Re: Lubricant
Couple different methods I've seen used - the coffee can method, where you fill a coffee can with oil, then dip the piston/rod assembly in, which pretty much covers everything (rings, skirt, wrist pin - the works), then oil up the walls and install.
I just take the oil can and run it around the rings and skirt and give it a good coat, then rub it around with my hand. Still oil the cyl. walls.
My personal preference for assembly lube on motors that are going to be sitting for a prolonged period of time is Redline assembly lube. That stuff seems to do a decent job on rust prevention and it sticks to surfaces well. Just a suggestion.
Karps TA
Apr 14, 2002 01:16 PM
Nemesis
Carburetors
Mar 24, 2002 06:23 PM
Vader
Mar 10, 2002 10:11 PM
bzznczzn
Jan 29, 2002 10:16 PM
P J Moran
Aug 14, 2001 12:37 AM
