what stall torque converter do i need for this cam also rear end gear ratio
Old Jun 17, 2009 | 07:58 PM
camarokid144's Avatar
my cam is advance duration (intake 288) (exaust 296)
duration at .050 (intake 252) (exaust 258)
valve lift (intake .631) (exaust .630)
lobe sep 114.0
ITS A COMP HYDROLIC ROLLER CAM
IS THIS THING STREETABLE
SHOULD I JUST GET ANOTHER CAM
IM ALSO RUNNING A 144 SUPERCHARY
I REALLLY NEED HELP THANKS
Old Jun 17, 2009 | 08:08 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: what stall torque converter do i need for this cam also rear end gear ratio
That's a pretty big cam for a street smallblock. That camshaft should use a converter with about 3800 stall if used on the street. About 4300-4500 for full race.
Gearing depends on tire size and how you want to run it. On the street, 3.73 is still a good compromise ratio but on the track something around 4.56 or deeper might be better.
I can't find those cam specs anywhere in the comp cams catalog.
Old Jun 18, 2009 | 04:49 PM
thanks for your prompt reply 3800 is streetable wow i new the cam was big but i didnt think that big
its a special grind cam i got a 3500 stall will i tear that up
Old Jun 18, 2009 | 06:06 PM
AlkyIROC's Avatar
Car: 87 IROC L98
You can run whatever stall you want but to get the best performance potential, the converter should be matched with the cams powerband.
hectre13
Dec 11, 2023 08:14 AM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
jklein337
Sep 19, 2018 06:23 PM
hectre13
Aug 26, 2015 08:17 AM
gwade12
Aug 8, 2015 08:17 AM
