88 trans am problem
Old Jun 21, 2009 | 06:13 PM
daatv's Avatar
Engine: 350 -5.7 l
Transmission: 5 speed
88 trans am problem
I have a 1988 trans am with 350 tpi when when i first start it it well stall after it warms up it will fluctuate between 600 to 800 rpm and when i turn the ac on it will drop down around 500 rpm i have also replace the block fan switch the fans should turn on at 200 and off at 180 but instead the turn on at 180 and off at 160 i replace throttle body ,new IAC valve, new fuel pump ,,new O2
censer,fuel filter,and check for vacuum leaks .I am at a lost hopefully some body can give me a new direction
84z96L31vortec
Aug 20, 2017 12:16 AM
TheJoeY88
Dec 31, 2016 07:30 PM
gta power
Aug 13, 2015 06:15 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
