Should Vacuum advance can hold vacuum?
Old Jun 23, 2009 | 07:38 AM
Alminate's Avatar
Car: 85 Camaro
Axle/Gears: 3.42 posi
I'm trying to track down the cause of a rough idle and occasional stalling that has started happening on my carbed 350 mated to a T-5.
I checked vacuum, jumps from 12-13" at idle. Then, I attached my vacuum pump to the vacuum advance and could not get it to hold a vacuum. If I pumped it vigorously I could get it up to about 5", but that would drop down to 0" about 2 seconds after I stopped pumping.
I know that the vacuum advance is advancing the spark somewhat, because the engine will stall at idle as soon as I unhook the vacuum line from the carb (manifold port).
Am I in the market for a new vacuum can?
Old Jun 23, 2009 | 09:35 AM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
Re: Should Vacuum advance can hold vacuum?
You're on to something. It shouldn't leak down like that. I don't know how big your cam is, but you should probably have higher manifold vacuum than you do. Advancing the timing (as long as it's not detonating) when using a bigger than stock cam can help increase manifold vacuum at idle. Replace the vacuum advance mechanism, they're pretty cheap. AFTERWARDS, take another look at your base timing.
83 Crossfire TA
Jan 3, 2016 01:26 PM
Jorlain
Oct 8, 2015 01:57 AM
86CamaroDan
Sep 29, 2015 10:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
angel2794
Sep 8, 2015 06:22 PM
