Help me pick a cam "goodwrench 350"
Old Jun 23, 2009 | 09:28 PM
camaro71633's Avatar
Car: 89 Camaro RS
Engine: 307
Transmission: thm350
Axle/Gears: open 3.73
I want to put a cam in my 89 rs. It has a "goodwrench" 350 crate motor. Im not sure if it is the 260 or 290 hp version i got it used. It is mated to a thm350 and the rear is a open 3.73. The car will be mostly a street car and maybe Ill make a trip to the strip once in a while. I am on a tight budget so im looking at summit brand cams. I was thinking the SUM-K1105 would be a good choice but i don't know for sure if it will work with the stock valve springs and such in my motor or if i have enough compression to run that size of cam. Any suggestions?
Old Jun 23, 2009 | 11:22 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: Help me pick a cam "goodwrench 350"
I can't remember if thats a roller cam engine, but if it is, I'd suggest an LT1 or LT4 cam. They are a pretty good match for the heads and valvetrain that are on that engine. Shouldn't have any clearance issues, and its a fairly easy cam to tune an engine for - either EFI or carb'd. Nice sounding cam with a nice street powerband (idle-5000 or so) with all its meaty torque between 1800-3500.
Old Jun 24, 2009 | 12:01 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Either of those crates come with low compression (8.5:1ish) and flat tappet cams.
1103 is about as large as I would go for your platform.
Old Jun 24, 2009 | 06:10 PM
Car: 89 Camaro RS
Engine: 307
Thanks for the help. Yes it is a low comp non-roller motor. I think I will go with the 1103 if i get some extra cash or I might just hold of until I get a better set of heads latter on.
junkcltr
Aug 2, 2019 11:12 PM
Street Lethal
Apr 30, 2019 12:14 PM
Below Average J
Members Camaros
23
Nov 18, 2015 10:03 PM
camaro71633
Sep 1, 2015 10:24 AM
Stauf
Aug 24, 2015 08:31 PM
