engine sufficate it self?
Old Jun 23, 2009 | 10:45 PM
Americanmouse's Avatar
Car: 1988 IROC-Z28
Engine: L98(383tpi) modified
Transmission: 700R4 rebuilt
Axle/Gears: 3:73 10bolt rebuilt
I have modified fully ported tpi 383. I've been dialing in the timing and idle in a hot 95º plus no air ciculating garage. The garage door is open with the rear of the car facing out. It starts up fine but as its running and goes into close loop. About 1-2 minutes into it the idle drops. from 700-800 rpms down to 4-500 rpms. then it just stalls out. Is the lack of no air ciculating other than the engine cooling fan running enough to kill the engine in the heat. I also have a slp cold air induction on the car. I can sometimes stop it from stalling by blipping the throttle. But it will try to do it again til it does die. I have not pushed it out of the garage because my other cars are on the driveway, and I don't want to move them til I know I can start driving the camaro.
Old Jun 23, 2009 | 11:14 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: engine sufficate it self?
Cold air won't help it. Theres something wrong, either mechanically or in the tune.
Old Jun 23, 2009 | 11:34 PM
all4u's Avatar
Car: Firechicken
Engine: 350 + 30 over, 400 crank
Transmission: autotragic, stalled
Axle/Gears: not a one tire fire, thank god!
I would take a closer look at the TPS and IAC. Next get a vacuum gauge to see what is going on. Also glance at the fuel pressure.
Old Jun 24, 2009 | 02:47 AM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
I agree with the replies you already got, I'd think that if you were in that garage with the car that you would die before it did.
Old Jun 24, 2009 | 02:36 PM
Car: 1988 IROC-Z28
Ok!
I'm starting to think my base/intial ignition timing is still off. That maybe I'm setting it wrong. Should I wait til the engine goes into close loop before I attempt to adjust the timing, or does it matter. If so should I wait til close loop before disconnecting the set timing connector wire, and can I do it while its running or what?
Old Jun 24, 2009 | 04:00 PM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
What heat range are your plugs?
Old Jun 24, 2009 | 08:39 PM
Car: 1988 IROC-Z28
My plugs are new Autolites #3923 gapped at .045, I believe they are colder plugs, and they clear my headers better. The good news I think I got it. I disconnected the battery to start fresh, and reset the base timing to 16 degrees btdc. She seems to like it. I'm now just working on the idle which seems to be best at 750 rpms.
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
