What Flexplate Was Used In 85?
Old Jun 25, 2009 | 03:39 PM
FireDemonSiC's Avatar
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
What would I be looking for if I was to order a replacement flexplate for my 85 Z28 equipped with a 305 and 700r4?
Slso, what is everyone's opinion on the lightweight flexplates? Doesn't look like they have a whole lot of meat to them...
Old Jun 25, 2009 | 06:39 PM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
Re: What Flexplate Was Used In 85?
Well what your would be looking for is just a standard flex plate for use with a 2 piece rear main seal (unless the motors been replaced with a newer one) and with the smaller tooth count i believe 153? Light wheel flex plates rea great in my oppinion as ther reduce a good amount of weight helping acceleration faster revs ect. If there strong enough for day to day street use? That would be someting to ask the manufacturer about because something like that may vary frombrand to brand depending on their perpouse and quality. I would say tmany of them would be fine for street use but again ide check with the manufacturer
Old Jun 25, 2009 | 06:46 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Correct, 2-piece rear main seal, 153-tooth (12-3/4").
Makes more sense to get a smaller torque converter than it does to get a lightweight flexplate. An SFI piece will take more abuse than a standard replacement, but it probably isn't necessary. A plain old Pioneer replacement will do for most applications.
Old Jun 25, 2009 | 11:14 PM
Car: 1985 Z28
OK. Last question.
How do I know whether I need an externally or internally balanced flexplate?
Old Jun 25, 2009 | 11:21 PM
You need the internally balanced flywheel.
Old Jun 26, 2009 | 09:45 PM
Car: 1985 Z28
OK I just ordered a 153 tooth PRW flexplate for a 2 piece internally balanced engine made out of chromoly.
But It's advertised as SFI approved and says 0.35" thicker than stock. Doon't I need tto worry about using a different spacer now?
Old Jun 29, 2009 | 05:49 PM
Car: 1985 Z28
Bump
Old Jun 29, 2009 | 09:01 PM
Well it depends in what way is it thicker. Ive heard of some that were machined thicker to compensate for the use of engine plates or it could just be thicker in a different way to be stronger yet bolt in like a factory piece. You really have to call the manufacturer for something like that.
84LsxZ28
May 17, 2020 02:21 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
Stangski09
Nov 14, 2015 01:27 PM
roysatikas
Sep 22, 2015 08:15 PM
roysatikas
Sep 7, 2015 08:08 PM
