not the iac. now what?
Old Jun 26, 2009 | 01:27 PM
panzer's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Axle/Gears: limited slip
Sometimes when I drive it and it warms up and come up to a red light it will sit at 500 rpms and outta nowhere it dropps below 500 then jumps to about 700 then goes back to 500.It would do that about 5 times then stop. Its gettin on my nerves because the whole car jumps when this is happening. Its doing it more frequently now. I cleaned the iac valve, checked it etc. Its the l03 tbi. It only does it at lights.
Old Jun 26, 2009 | 01:47 PM
spimonkey34's Avatar
Car: 1989 Firebird
Engine: 2.8 V6
Transmission: 5 Speed
Re: not the iac. now what?
I had a problem with the EGR valve sticking that would cause this type of problem. It would run fine cold, then after about 5 minutes or so, when I would stop to idle, it would bounce around. I plugged the vacuum line going to the EGR just to test it and it went away. Replaced the valve, now it's perfect. Hope this helps.
Old Jun 26, 2009 | 07:10 PM
panzer's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Would it hurt to just delete the egr? I was gonna take it off anyways. I heard that if you do the car will run either lean or rich. I just wanna be safe before I take that kinda stuff off. I will definately check it out though.
Old Jun 27, 2009 | 11:59 AM
Car: 1989 Firebird
Engine: 2.8 V6
i have heard it decreases gas mileage. I ran without it for about a month and didn't notice anything different. Just remember if you do, make sure to plug the vacuum line or it may throw a code.
Old Jun 28, 2009 | 02:40 PM
panzer's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
i plugged the line and it stopped jumping at lights and I noticed a huge power difference. Its got alot more top end power. So its gonna come off. I just need to fabricate a nice resrictor plate.
Old Jun 28, 2009 | 03:42 PM
Car: 1989 Firebird
Engine: 2.8 V6
Good to hear you found the problem!
86IROC112
Nov 27, 2015 09:54 AM
tonys91rs
Oct 26, 2015 12:11 PM
L98GTA87
Oct 19, 2015 10:43 PM
bamaboy0323
Sep 3, 2015 06:07 AM
86IROC112
Aug 21, 2015 07:20 PM
