Chipped piston skirt. Why did it run perfectly fine?
Old Jun 26, 2009 | 02:00 PM
PPM's Avatar
PPM
Car: 1991 Chevrolet Camaro Z28
Transmission: Tremac T-56 6 Speed
Axle/Gears: 10 Bolt 3.73 POSI
I just pulled the 350 out of my other camaro. Wanna build a 388. I took it apart and found a very slightly chipped piston skirt. Was wondering why it ran perfect with no vibration problems or anything?
Old Jun 26, 2009 | 02:11 PM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
Re: Chipped piston skirt. Why did it run perfectly fine?
The chip in the piston skirt wasn't enough weight to throw the engine's balance off significantly. Good thing it was just the skirt and not a shattered piston
Old Jun 26, 2009 | 03:33 PM
Guest
Guest
Posts: n/a
I've seen that a lot, with no complaints from the vehicle owner. As mentioned its not a lot of weight loss so most dont notice it.
Frozer!!!
Jan 19, 2024 04:55 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
kyleb24
Aug 15, 2015 08:24 AM
BBSDesigns
Aug 11, 2015 07:39 PM
Exxon Limited
Aug 9, 2015 08:13 PM
