Mischievous head lights
Old Jun 28, 2009 | 03:22 PM
YoungMoneyVII's Avatar
Car: 1990 Pontiac Firebird T-Tops
Engine: V8 350 5.7 L TPI
Transmission: Overdrive 700R4 (Auto)
Axle/Gears: 9 Bolt/GU5AXLE,REAR3.23 RATIO3.23R
My headlights are giving me problems if you look in my profile at the album I posted today there is pictures of both headlights and a description of each. thank you for your time! =)
Old Jun 29, 2009 | 04:58 PM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
Re: Mischievous head lights
Judging from your description, the headlight motors are shot. You can either go to your local parts store and order some remanufactured ones or you can open up the gear assemblies and rebuild the bushing assembly yourself. There's a kit that can be ordered, I believe Top Down Solutions sells it, but don't quote me on that.
The driver side motor doesn't look like the correct one for that year.
Jae992
Aug 27, 2015 09:07 AM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
