Mischievous Popup Headlights
Old Jun 29, 2009 | 08:31 AM
YoungMoneyVII's Avatar
Car: 1990 Pontiac Firebird T-Tops
Engine: V8 350 5.7 L TPI
Transmission: Overdrive 700R4 (Auto)
Axle/Gears: 9 Bolt/GU5AXLE,REAR3.23 RATIO3.23R
My headlights are giving me problems.
Facing from the front Left Headlight Gear, This headlight will go up sometimes when i push the button or just make the grinding noise and stay shut and will not open up when pulled upon it is quiet stubborn.
Facing from front, Right headlight gear, this headlight does not go up at all sometimes when the button is pushed or only halfway and has to be manual opened. If I hit a bump on the road this headlight falls down so at night i drive like Mr. Magoo swerving potholes and bumps lol. Any help please? thank you greatly appreciated.
Old Jun 29, 2009 | 08:57 AM
89-bird's Avatar
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
Axle/Gears: open/3.42
Re: Mischievous Popup Headlights
You need the rebuild kit for the motors they are little plastic pieces that wear out over time but one problem I can see is that the motor on your passenger side is correct and the one on the driver side is for the 82-86 IIRC so it is wrong for your 90 model .
Old Jun 29, 2009 | 09:22 AM
89 bird, thank you so much i thought it might of been that since there both different. Where can I get a rebuild kit or a motor for my car? A junkyard?
Old Jun 29, 2009 | 09:31 AM
89-bird's Avatar
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
You could go to the JY but I would check on here for one I think 1A auto or some others could have the motor and rebuild kit for a decent price . Just do a search for it .
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
