1988 Iroc rev limiter?
Old Jun 29, 2009 | 02:41 PM
camaro1185's Avatar
Car: 1988 Iroc
Engine: 5.7L
Transmission: '96 T56, Hurst Shifter, Mech VSS
Axle/Gears: 3.45 9 Bolt
So i just got a 88 iroc 350, and had to do some "safety" work to it before i drove it. This weekend i drove it for the first time (i didnt test drive it due to it not being reg). I had my buddy in the car (showing off) and got on it hard, and next thing i knew i had the RPM need pinned all the way to the left (maxed out). i would have thought that these cars have a rev limiter where once you hit the redline, it cuts the gas to the engine. I will never rev that high again, but want to know if there was a limiter on these cars.
Old Jun 29, 2009 | 03:09 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: 1988 Iroc rev limiter?
No rev limiter. You'll be lucky if nothing was damaged.
Old Jun 29, 2009 | 03:46 PM
camaro1185's Avatar
Car: 1988 Iroc
Engine: 5.7L
Thanks for the info. I seriously doubt anything was damaged.
Old Jun 30, 2009 | 04:39 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
There is a rev limiter but it's probably set ~10000 in the prom. Essentially disabled.
theshackle
Sep 17, 2020 08:26 AM
86White_T/A305
Aug 17, 2015 12:16 AM
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
kyleb24
Aug 15, 2015 08:24 AM
mustangman65_79
Aug 11, 2015 03:17 PM
