starting problem
Old Jul 3, 2009 | 10:27 PM
BladeX10's Avatar
Car: 1991 RS v8
starting problem
My car seems to have a starting problem. When you turn the key it will start just fine. Then theres times where you turn the key and all you hear is a "click" sound and thats it. Turn the key off and turn it back on and it starts no problems. Its just a weird problem. Any ideas on what it is? Im just getting back into the camaro game so i kinda lost some of my chevy knowledge lol
Old Jul 4, 2009 | 12:14 AM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
Re: starting problem
Sounds like a bad starter to me but check your battery connections and the connections at the starter
Old Jul 4, 2009 | 12:48 AM
BladeX10's Avatar
Car: 1991 RS v8
How hard is it to change starters on third gen camaros? I know its a complete bitch to change them on fox body mustangs
Old Jul 4, 2009 | 12:54 AM
Then your in for a treat because in the camaors its a breeze. The hardest part is just haveing to jack up the car and crawl around underneeth. Its in most case 2 bolts and 2 wire connections that are all easy to get to. Some have a support in back bust again thats easy to remove as well as its only 1 additional nut to remove.
Old Jul 4, 2009 | 12:57 AM
BladeX10's Avatar
Car: 1991 RS v8
Alright cool.. So you think that what it is? Sometimes it takes 3 times to get it to crank over and other times it starts the first time
Old Jul 4, 2009 | 01:09 AM
Well me first guess is a bad connection as bad connections can do that stuff to you and starters are fairly reliable more so than the connection on these older cars. You can you can hear the staters solenoid clicking but nothings happening so that tells me the wireing/ignition switch is ok. So if not a bad connection ide say a bad starter motor.
Old Jul 4, 2009 | 07:14 AM
92tracker's Avatar
Car: 92 firebird formula
Engine: 2002 LS1/6 350 rwhp
Transmission: 4L60e
Axle/Gears: 342
could it be a worn key try using a new key or it my be in the coloum.
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
92camaroJoe
Aug 13, 2015 06:07 AM
mustangman65_79
Aug 8, 2015 12:07 PM
