1.6 roller rockers with vortec heads?
Old Jul 5, 2009 | 11:11 PM
danielmonster's Avatar
Car: 1985 IROC
Engine: lb9
Transmission: 700R4 B&M shiftkit
Axle/Gears: 3.42s
I have a vortec combo right now that is running 12.6 at 110 at the track. The heads have been modified for .600 lift with 330lb springs and screw in studs. My cam is 290/306 duration with .510lift/.540 lift on the intake and exhaust respectively. Surprisingly i've found the ideal shift point to be ~6800 rpm. Swapping to 1.6 roller rockers from the stock stamped steel would yield .544 lift on the intake and .576 lift on the exhaust. From what i've read, stock casting vortecs intake flow peaks at around .480 lift. The exhaust flow hits a plateau. I know that I will see horse power increase from the reduced friction. My question is will eclipsing the threshold of the intake flow diminish any hp gains? Something to take into consideration is that with more valve lift, the valve will stay open longer allowing more air to enter the combustion chamber, but will the decreasing flow past this threshold even net any extra air? Would I see a low of low-end torque and a slight increase on the topend?
Old Jul 5, 2009 | 11:24 PM
Sooner's Avatar
Car: 1982 4cyl 4spd/ 1980 z28
Re: 1.6 roller rockers with vortec heads?
If you do go to a 1.6 rocker, dont forget to enlongate the pushrod slot in the head with a 1/2 inch drill bit to keep from bending the crap out of your pushrods.
Old Jul 6, 2009 | 12:26 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
I suspect you won't notice much of anything from changing rocker arms, either from the ratio, or the roller aspect. If anything, the increase on the exhaust will be more beneficial than the intake side.
Old Sep 12, 2009 | 01:02 PM
naputir's Avatar
Engine: 305 tbi
need help can i put a noisy gear drive in my 1991 rs camaro if anyone has done this before can you guys let me know what to do thanks
midge54
Dec 27, 2019 04:14 PM
gixxer92
Sep 1, 2015 04:32 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
LT1Formula
Aug 20, 2015 09:36 PM
Dialed_In
Aug 20, 2015 01:45 PM
