fuel gauge problem (anyone else)
Car: 1991 RS (sold), 1991 Z28
Engine: LO3, L98
Transmission: T5, 700r4
Axle/Gears: 2.73, 3.23
sorry if this has been posted but i can find the problem, so if there is a thread already, please let me know.
Does anyone else have the problem when they are braking from a decent speed and your fuel gauge starts to plummit to Empty on the gauge scale, and then rises back up to its original (or close enough) position.
If so, how would i fix this (if its possible) i dont want to have that doing that, i plan on putting in a digital gauge (much later on) in the future and it would be a pain if that problem occured with a digital gauge.
Transmission: 4L80E/4L80E
Not sure if anyone else has that problem, but unless your gauge isn't functioning properly, everyone will have that happen.
The fuel sloshes to the front of the tank when under hard braking, lowering the level of fuel the sending unit sees. It's just a simple float, after all.
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
Re: fuel gauge problem (anyone else)
I don't know if it has anything to do with mine being older, a 1982, but my guage gives instant readings meaning that it bounces all over the place if the fuel is sloshing around.
Car: 92 GMC Sierra 2500
Engine: 5.7l
Transmission: 4L70
Axle/Gears: GT4 3.73
Some vehicles like trucks with a long fuel tank and the long being from front to rear have a "sloshing damper" which is a baffle inside the tank.
There are also electronic circuits which can solve this problem as well.
For more on this, following is a search for google.com for the words...
fuel tank slosh damper
http://www.google.com/search?hl=en&s...er&btnG=Search
Car: 1990 Iroc-Z28
Engine: 350HSR
Transmission: HD 700r4 B&M Stage2 SK
yea ive been having this problem as well, if i brake hard or take a long hard left curve it will go down. its really bad cuz if i have any less that a quarter tank the car will die out if i brake hard when the needle hits EMPTY.
Ghettobird52
Jul 5, 2024 11:18 PM
