Weird popping noise!!!
Old Jul 6, 2009 | 07:18 PM
355RS's Avatar
Car: 1991 Teal Green Camaro RS
Transmission: built 700r4
Axle/Gears: 3:42
My car had been having problems with back fires, which I thought would be resolved by installing a new electronic ignition box. Well, I was wrong..... when I start the car it idles very rough and will turn off if I dont step on the throttle. When I step on the throttle popping noises start and fire starts shooting out from the exhaust! What could be the problem that is causing this?
Old Jul 7, 2009 | 01:37 PM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
Re: Weird popping noise!!!
sounds like an overly rich mixture. Any check engin codes? Its backfireing in the exhaust correct?
Old Jul 7, 2009 | 01:45 PM
355RS's Avatar
Axle/Gears: 3:42
Havent checked for engine codes, but you are correct the backfires are coming from the exhaust.
Old Jul 7, 2009 | 02:15 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Double check your firing order - I know, you did, but do it again, with a witness lol.
Make sure all plug boots are on firmly.
Check resistance on each plug wire one at a time - even brand new plug wires are bad (more often than you'd think).
I'm no expert, but every backfiring issue I've had was an electrical issue, not a fuel issue.
Good luck!
Old Jul 7, 2009 | 02:31 PM
355RS's Avatar
Axle/Gears: 3:42
yeah I'll have to get one of my buddies to help me with the firing order lol. What is the normal resistance range for the plug wires?
Old Jul 7, 2009 | 09:04 PM
Car: 1992 RS
Engine: Carbed 350
Sorry - I didn't mean restistance, but couldn't think of the right term at the moment - I meant CONTINUITY. I don't know what normal resistance range should be - just make sure it's low (ie alot of continuity) so you know you're getting fire to the plugs. I've bought plenty of New plug wires that were broken inside, or had shorts.
RS Reaper
Oct 17, 2018 07:52 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
Luigytico09
Oct 1, 2015 08:46 AM
aaron7
Sep 30, 2015 09:15 AM
