low oil pressure when accelerating
Old Jul 7, 2009 | 12:09 AM
Nater2491's Avatar
the oil pressure is fine at idle and when normal driving, but as soon as i nail the throttle the oil pressure drops to almost 10, any ideas on what it might be ???
Old Jul 7, 2009 | 12:14 AM
Nater2491's Avatar
Re: low oil pressure when accelerating
also forgot to mention i do have a mechanical fuel pressure gauge so its not a bad sending unit. i think its the oil pump but just want other suggestions
Old Jul 7, 2009 | 12:53 AM
1986iroc350's Avatar
Car: 1986 Iroc z
Engine: 350 tpi
May be a bad gauge itself. Just a suggestion. maybe a clogged oil filter or crushed partially? Or maybe a bad filter. I know it happens but its not uncommon to have a bad oil filter. It may be new but maybe manufacture glitch. Not so sure on the oil pump. im not good at internal parts. Good Luck
Old Jul 7, 2009 | 01:00 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
if the gauge is correct, it most likely is your pump on its way out.
Old Jul 7, 2009 | 02:19 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
If the gauge is correct, it probably means that the pickup has fallen off.
Old Jul 7, 2009 | 08:42 PM
Nater2491's Avatar
well guys, i went to start the car today, and now it smokes all the time. i think the motor is done. should have never drove it with the low oil pressure problem.motor only had 53,xxx miles on it. all original
89GTAOz
May 16, 2020 09:31 AM
db057
Aug 22, 2015 08:17 PM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
