Custom power steering install. > questions..
Old Jul 8, 2009 | 10:12 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
hey guys I installed a lt1 power steering pump from a camaro z28 '95. and can someone take a look at my diagram how I installed it and make sure I did it right? also, i see lots of big bubbles come up while im idling and my turning isnt any easier yet, my fluid level isnt really going down much either. im quite sure my gear box and the new pump is empty, how much does this system hold? I have gotten about half a quart into the system so far, my resevoir holds half a quart and its about 3/4-1/2 full right now. any tips?
Attached Thumbnails Custom power steering install. > questions..-psschem.jpg
Old Jul 8, 2009 | 11:01 PM
Krik's Avatar
Car: 1990 IROC-Z 1LE
Engine: 5.7 TPI
Axle/Gears: G92 3.23
Re: Custom power steering install. > questions..
I read somewhere that the third gen pump spins the opposite way of the 4th gen one. You may be pumping fluid the wrong way.
Why did you choose to do this anyway?
Old Jul 9, 2009 | 01:15 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
would it matter as long as the lt1 pump does turn clockwise and the pressure side from the pump is going into the bigger 18mm fitting on the gear box? and the 16mm fitting is returning to the resevoir then back to the pump?
I chose to do this because my F1 bracket does not leave room for any kind of conventional-to-thirdgens power steering pump so I had to go to a gm type-2 and I chose a lt1 style for its 5/8" neck coming off of it already.
Old Jul 9, 2009 | 08:06 AM
Thomas Aquinas's Avatar
Car: 1986 Iroc
Engine: Afr 408
Transmission: T56 Magnum
Axle/Gears: Moser 9" 3.70s
I'm about to get a procharger soon and have read about it on their site. They state that the Type 2 will give you the clearance, and give a Napa #20-704 or the 20-875. So maybe cross reference the one you have?
On a side note, do you have any pics of your setup? Maybe showing the bracket, p.s mounting. Do you have a stock hood?
Old Jul 9, 2009 | 08:40 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
their kit is nothing more then a 150 dollar chunk of aluminum. I made my own mounting with march brackets I had laying around.i dont have any good pictures because the mounting is so low, and I have a 2" cowl hood.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
evilstuie
Apr 14, 2016 08:52 PM
Dialed_In
Aug 20, 2015 01:45 PM
