Help diagnose my Check Engine light?
Old Jul 6, 2009 | 12:59 AM
ROFLsplash's Avatar
Car: 1987 Trans Am
Engine: 5.0 L
As far as I know and can tell, there is nothing wrong with the car at all. I checked the O2 sensor and it didn't appear to be faulty, the car isn't overheating, oil pressure is good, doesn't stall, everything appears to be fine! Any help diagnosing what could be "wrong" with my car?
Old Jul 6, 2009 | 01:13 AM
novafirebirdguy's Avatar
Car: 90 Formula WS6, 86 Sport Coupe
Engine: 305 TBI, 2.8 MPFI
Transmission: 700r4, 700r4w/vette servos
Axle/Gears: 2.73 Open, 3.42 Open
Re: Help diagnose my Check Engine light?
The check engine light has to do with emissions stuff so your car will generally run fine when it comes on. If you take your car to advance auto they have a code scanner and will tell you whats wrong with it.
Alex
Old Jul 6, 2009 | 01:32 AM
ROFLsplash's Avatar
Car: 1987 Trans Am
Engine: 5.0 L
Alex
I did, but they only have OBD II scanners, and most 3rd gen firebirds use OBD I codes/scanners
Old Jul 6, 2009 | 02:15 AM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Copied from a Vader post:
Insert a tool as described above (paper clip) into the 'A' and 'B' terminals on the ALDL connector:
WITHOUT STARTING the engine, turn the ignition to the "RUN" position. Watch the Malfunction Indicator Lamp (MIL) - it will begin to flash. This is also commonly called the "Service Engine Soon" or "SES" lamp. The first code will flash three times, and will usually be a code '12'. This is encoded by one flash of the lamp, a brief pause, then two successive flashes of the lamp. Each code will repeat three times, so you should see a "Code 12" flash three times. Any other error codes will follow in numerical order, and each code should flash three times. After all codes have been displayed three times, the "Code 12" will again flash three times, then all other codes will follow as described earlier. This cycle will continue until the jumper is removed or the ignition is turned off.
After you have made a note of all error codes, turn off the ignition and remove the jumper immediately. If you forget to remove the jumper and attempt to start the engine with it in place, you could damage the ECM. For this reason you should remove it immediately.
Old Jul 6, 2009 | 10:03 AM
Sparkytfl's Avatar
Car: 85 TA (sold), 88 Corvette, 02 Monte
I hope I don't get stoned for linking to a "rival site", but here's a list of error codes and a picture of which terminals http://www.austinthirdgen.org/index.php?pid=27
Old Jul 6, 2009 | 10:54 AM
ROFLsplash's Avatar
Car: 1987 Trans Am
Engine: 5.0 L
I did as directed and put a paperclip in between terminal A and B (which I believe are the top right and the one to the left of it), but when I put the ignition in the on position, the "Service Engine Soon" light just stays on, like it would any other time. Any ideas as to why that could be? (possibly poor connection?)
Old Jul 6, 2009 | 11:02 AM
89-bird's Avatar
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
Axle/Gears: open/3.42
Your light should go flash pause flash flash for a code 12 meening nothing is stored and the computer is functioning right so you may want to look into that light staying lit .
Old Jul 6, 2009 | 12:07 PM
Billy_Bob's Avatar
Car: 92 GMC Sierra 2500
Engine: 5.7l
Transmission: 4L70
Axle/Gears: GT4 3.73
Take note of where the little black tab is as shown on the following diagram and where this is on your connector. (So you are sure to be using the correct terminals...)
Old Jul 6, 2009 | 12:33 PM
ROFLsplash's Avatar
Car: 1987 Trans Am
Engine: 5.0 L
Yeah, it's set up exactly like that, I was using the right terminals. But for some reason there are no metal connectors on the bottom row, and I believe the second on the left is also missing
Old Jul 6, 2009 | 12:43 PM
Billy_Bob's Avatar
Engine: 5.7l
Transmission: 4L70
On mine, this is the connector under the steering wheel and the top row is the row closest to the driver.
Might try turning on the ignition, then briefly shorting the two connections. (As opposed to leaving it shorted).
Old Jul 6, 2009 | 12:44 PM
89-bird's Avatar
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
So you are putting the jumper in a/b and the light does not flash ?
Old Jul 6, 2009 | 07:01 PM
ROFLsplash's Avatar
Car: 1987 Trans Am
Engine: 5.0 L
Yep, when I turn the ignition the light does what it normally would (stays on, like all cars do)
Old Jul 6, 2009 | 07:24 PM
ROFLsplash's Avatar
Car: 1987 Trans Am
Engine: 5.0 L
This is an image of my terminal. I connected the top two on the right. Notice that most of them have no leads?
Old Jul 6, 2009 | 07:27 PM
Billy_Bob's Avatar
Engine: 5.7l
Transmission: 4L70
As a double check, might want to see if you can read any codes with a code reader.
Otherwise, disconnect the ECM cable from the computer, then turn on ignition and see if the light is still on. If yes, then a short in the wiring or instrument cluster.
If off, then might indicate a problem with the ECM eprom or the ECM.
When getting much involved with problems such as these, it is best to follow the troubleshooting instructions in a GM factory service manual.
Old Jul 6, 2009 | 07:30 PM
ROFLsplash's Avatar
Car: 1987 Trans Am
Engine: 5.0 L
I did go to autozone and they checked it but couldn't get any readings, but of course they probably use and OBD II device, should I try and buy an OBD I before proceeding?
Old Jul 6, 2009 | 07:58 PM
Billy_Bob's Avatar
Engine: 5.7l
Transmission: 4L70
If the connector fit your connector, then that should have been the correct code reader. So that is a confirmation there might be a problem with the ECM or eprom.
Most important would be to get a factory service manual. This will tell you where various components are located which is the MOST important thing! (Where is that darn ECM located?)
First I would try removing the ECM connector per the factory instructions. These things are sensitive to static, etc., so best to read all the warnings and do everything step by step as it says.
You can order factory service manual sets from the following link or at a GM dealer.
http://www.helminc.com
FYI - I was just reading about the eprom data retention span being 20 years, maybe you are the first with this trouble?
https://www.thirdgen.org/forums/dfi-...tion-span.html
Old Jul 6, 2009 | 08:02 PM
ROFLsplash's Avatar
Car: 1987 Trans Am
Engine: 5.0 L
Thanks a lot, that will probably have to be my next step of action, so i'm just gonna have to wait for that service manual to come in! And about the retention span life: Yeah, that'd probably be my luck!
Old Jul 6, 2009 | 08:26 PM
Billy_Bob's Avatar
Engine: 5.7l
Transmission: 4L70
BTW for older vehicles factory service manual sets may have 3 or 4 different books to the set. There might be a general service manual, an electrical diagrams manual, a fuel and emissions manual (engine and engine computer stuff), and a unit repair manual.
Newer vehicles might have everything integrated into a set of several books.
Anyway I find myself frequently flipping between the various books for the same problem. One might show the location of a device, another the wiring diagram, and another information for troubleshooting.
Old Jul 6, 2009 | 08:33 PM
ROFLsplash's Avatar
Car: 1987 Trans Am
Engine: 5.0 L
And i'm guessing a Hanes/Chilton manual just isn't enough?
Old Jul 6, 2009 | 09:29 PM
Billy_Bob's Avatar
Engine: 5.7l
Transmission: 4L70
Well for my vehicles I have those too. Sometimes I need all the help I can get and it helps to get all the information I can. Sometimes the factory manuals go on and on about something and I can quickly look it up in the other manuals.
But to give you an idea of the information in the factory manuals, I have a 99 GM C/K truck with 4 books to the set and each book is 2 inches thick!
That's about 3,000 pages of information! And only on 1999 C/K trucks.
For a 92 manual, the electrical manual is 11 inches by 17 inches and about 300 pages long. All just electrical diagrams, layouts of harnesses, locations of each electrical device in the vehicle, connectors, where each connector is located, etc.
Old Jul 9, 2009 | 09:19 AM
89-bird's Avatar
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
I hope you only have a short or something else and not a bad computer .
Wade787b
Sep 29, 2015 01:15 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Omega
Aug 10, 2015 12:46 PM
