engine building question
Old Jul 9, 2009 | 05:01 PM
GTAman's Avatar
Car: 1988 Trans am GTA
Engine: corvette 350 swap
Transmission: t-5 swap
Axle/Gears: 3.27:1 borg warner 9-bolt w/ PBRs
I want to get a 350 built for my gta. I'm on a budget and wondered what would be more cost effective buying a new block and parts or buy a used engine? Its going to be a 4 bolt main block with vortec heads.
Old Jul 10, 2009 | 10:28 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: engine building question
if you're keeping it TPI you don't need 4 bolt mains. Being a GTA, it already has a 350 you can rebuild. Going with all new parts is unnecessarily expensive.
Old Jul 10, 2009 | 10:56 AM
GTAman's Avatar
I originally had a 305 in it but it blew so I'm starting from scratch. I dunno if I should buy a new block or a whole used engine.
Old Jul 10, 2009 | 12:33 PM
Big Dog Chevy's Avatar
Car: A lot and 86' Z28 and 88' Camaro
Engine: 305, 383 and 565
Transmission: 700R4, th400 and 4L80
Axle/Gears: Frd 8.8 /3.27 and S60
How much is in your budjet?
Old Jul 10, 2009 | 11:46 PM
GTAman's Avatar
Unfortunately not much. I can manage about 2k,maybe 3 if they cut me some slack.
Old Jul 11, 2009 | 10:30 AM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
You should be able to find an '87-up 350 without heads for $100-150, or a '96-up Vortec 350 for around $450-500, and start disassembling it.
Old Jul 11, 2009 | 12:42 PM
Do you want to keep it efi or are you going carb cause you can build a stout 350 for $2-$3k.
Terrell351
Jun 13, 2021 01:13 PM
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Aug 16, 2015 11:40 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Jake_92RS
Aug 11, 2015 10:39 AM
