New crate engine Flexplate and starter question
Old Jul 9, 2009 | 05:42 PM
THETANK's Avatar
Car: 91 rs
Engine: Carbed 355 CR 9:1 xr276 cam
Transmission: 700r4 2600 stall
The crate engine that I am getting has a 168 tooth Flexplate. I wanted to change the flexplate to a 153 tooth flexplate due to clearance issues with my hedman shorty headers and y pipe. My question is can I just bolt on any 153 tooth flexplate for a 350 with a one piece rear main seal? I am also looking at the powermaster 9600 should that work with this comb(not sure how to tell if its inline or staggered)? If not could you suggest something that would work with this setup
355
1 piece rear main
The crate I am getting is the CT350PC1 from yearone
Old Jul 10, 2009 | 10:07 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: New crate engine Flexplate and starter question
you'll get alot more replies if you'll post links to each thing you're considering.
Old Jul 10, 2009 | 10:19 AM
THETANK's Avatar
Car: 91 rs
http://www.yearone.com/serverfiles/f...ain2.asp?cat=G
i cann't get it to link directly to the engine PN is : CT350PC1
Flexplate:
http://www.summitracing.com/parts/QTI-RM-932/
OR
http://www.summitracing.com/parts/BMM-20238/
Starter:
http://www.summitracing.com/parts/PWM-9600/
Old Jul 10, 2009 | 10:26 AM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
from the info available, you can use that starter with either flexplate with that engine.
84z96L31vortec
Aug 20, 2017 12:16 AM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
