fuel tank sending unit confusion
Old Jul 10, 2009 | 02:34 PM
antielvis's Avatar
Car: 1987 20th Anniv. IROC-Z Convertible
Engine: 5.0 TPI
Transmission: 5 Speed
Went to change the electric fuel pump on my '87 IROC, 5.0 TPI, and found the reason my gauge doesn't work, either. When I had the pump changed a couple years ago, the mechanic cut the gauge wire and removed the gizmo that sends the signal Wish I still lived in Nashville so I could go back and raise hell, but will have to chalk this up as lesson learned I guess. Problem I'm having now is that my wiring harness code from the old unit is FEU and all the replacements I'm finding are FPH. Does anyone know the correct code I need? I'm wondering if this is correct or if the previous owner changed in a different one from some other vehicle. Looking around the web, I'm not finding the FEU listed anyplace. With the weather so nice, I'm getting edgy not being able to get out and go topless.
Old Jul 13, 2009 | 01:17 PM
antielvis's Avatar
Engine: 5.0 TPI
Re: fuel tank sending unit confusion
Starting to think that if this is the right code on mine, maybe FEU and FPH are the same thing. Guess I'll just have to get one and see...
Old Jul 13, 2009 | 01:35 PM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
Not certain if the codes indicate a different sender, most should be the same, the biggest differences I've ran across have been wire colors.
Glowsock
Jul 24, 2025 03:15 PM
Ghettobird52
Jul 5, 2024 11:18 PM
Infested
May 22, 2018 11:56 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
