Car dies on acceleration
Old Jul 12, 2009 | 02:29 PM
trashed z28's Avatar
I have an '87 Z28 auto w/305 Carb engine. From a dead stop when you hit the gas it the rpms drop and it dies. It does this when cold and when warm. If I can get it cruising and punch it it accelerates just fine other than being hella slow. Any ideas on what can be causing my rpm drop and dying? I ran some carb cleaner thru it but didn't have any effect.
Old Jul 12, 2009 | 11:46 PM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
Re: Car dies on acceleration
2 things check your timing and look for vacuum leaks. Also try pulling a few spark plugs i suspect they may be on the white side.
Old Jul 13, 2009 | 07:23 PM
Stevolwevol's Avatar
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
I would also check the fuel pump pressure.
Old Jul 13, 2009 | 07:32 PM
I'll check the vac lines and spark plugs tonight once the temp gets below 100 degrees. I'll probably also order an in-line pressure gauge for checking the fuel press.
Old Jul 13, 2009 | 08:50 PM
anyone think if could be related to the fact the my alternator is shot? had a good charge the other day and ran great, i guess as the battery started wearing down the problem became more noticeable til today i tried to start it after 2 days of sitting and the battery is toast. So could this acceleration issue be directly related to my charging system dying?
Old Jul 13, 2009 | 08:58 PM
Sounds like you found the problem. Replace the alternator and drive it. Just don't drive too fast or anything lol Replace the battery also..
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Wade787b
Sep 29, 2015 01:15 PM
killer777
Aug 8, 2015 02:47 PM
