Camshaft replacement
Old Jul 14, 2009 | 08:33 AM
SolarGoldRaptor's Avatar
Car: 1984 Pontiac Firebird Trans Am
Engine: V8 5.0L HO (L69)
Transmission: B&W T5
Axle/Gears: 3.73 limited slip
Hi,
I'm totally new to the engine modification so pardon my newbie questions
So the L69 of my T/A has an Edelbrock 7102 camshaft with the hydraulic lifters that came with it, but I want to put back the original camshaft in.
Do I have to replace the bearings ?
Do I need new lifters ?
Thanks, Bye
Old Jul 14, 2009 | 01:49 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Re: Camshaft replacement
Why would you put the original cam back in?
So long as you're careful while removing the cam as to not knick the bearings, they can be reused.
Yes, you'll need new lifters.
Old Jul 21, 2009 | 08:37 AM
Ok, thanks for the help
I'm putting the car back to original, I bought her with this camshaft in.
Old Jul 21, 2009 | 09:29 AM
ap72's Avatar
you're better off leaving the cam you have in there. If you want to swap to an original cam you'll need a new cam and lifter set to be safe, plus all of the gaskets.
Caspar
Jun 19, 2016 11:19 PM
Reddeath210
Oct 6, 2015 08:20 AM
gta90
Sep 15, 2015 04:00 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
Jake_92RS
Aug 17, 2015 09:42 AM
