Squishy Clutch Pedal
Old Jul 20, 2009 | 07:01 PM
Trippeh's Avatar
Car: 91 Camaro RS
Engine: 5.0 TBI
Today on the way home after a long trip, merging off the interstate I noticed the clutch pedal felt much weaker than usual. My clutch pedal has always been really stiff though, (so much that my wife refuses to drive it). It still shifts through all the gears normally, clutch still seems to be working.
When I got home I popped the hood and checked the round container near the firewall on the drivers side, which I assume is the clutch fluid reservoir.
It looked a tad low, nothing much, but the color is brown, which doesn't seem good.
Any ideas of what I could check to isolate the problem?
Thanks.
Old Jul 20, 2009 | 07:08 PM
BackNBlack's Avatar
Re: Squishy Clutch Pedal
Look at the pushrod connected to the clutch fork to see if the pressure is bleeding out of the system. I would recommend flushing out the fluid too. The system is set just like brakes, if air gets in, its a no go!
Old Jul 20, 2009 | 07:35 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
flushing the clutch & brake system is a very overlooked item . when the fluild gets brown , time to flush . good luck .
Old Jul 21, 2009 | 01:50 AM
84Z28406's Avatar
Car: 1984 Camaro Z28 T-tops
How does one bleed or flush the clutch? Is there a bleed nipple on the clutch cylinder like there is on brake calipers?
Old Jul 21, 2009 | 05:00 PM
SMURFN' Z28's Avatar
Car: 1994 Jeep Wrangler
There is a bleader screw on the slave cylinder. I can't remember if it is allen or torx.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
meeklay812
Oct 1, 2015 03:46 PM
mfp189
Sep 27, 2015 09:25 AM
ironbmt
Sep 27, 2015 06:00 AM
