oil pressure
Old Jul 15, 2009 | 11:42 PM
sparky85's Avatar
Car: 85 camaro
Engine: sbc 400 .30 over
Transmission: 700r4 with bm shift kit, 2200 stall
Axle/Gears: 7.625 10 bolt posi
oil pressure
does any one know what the standard oil pressure is for a 305 high output
Old Jul 18, 2009 | 05:16 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: oil pressure
10 PSI per 1000 RPM, or better.
Old Jul 19, 2009 | 02:42 AM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
Re: oil pressure
On a hot day, with engine temp over 200*, idling, and in gear, my 192,XXX mile LG4 (an LG4 should make the same pressure as an L69) will make about 25 psi.
At cold idle in neutral the oil pressure is about 35 psi.
83 Crossfire TA
Jan 3, 2016 01:26 PM
angel2794
Sep 8, 2015 06:22 PM
Strick1
Sep 4, 2015 07:11 AM
solocus
Sep 2, 2015 12:14 PM
