timing help please
Old Jul 16, 2009 | 06:18 PM
schottout's Avatar
timing help please
i have a 350 with vortec heads summit racing intake manifold and an edelbrock cam am i able to use the stock timing set and just line up the timing marks or do i need to buy a new set also my dizzy wont sit flush with the intake manifold any suggestions
Old Jul 16, 2009 | 06:45 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: timing help please
You can use the old timing chain and sprockets if the chain isn't stretched too much. I would install new ones.
The distributor doesn't sit flush because it needs to engage the oil pump. Remove the distributor and using a long flat bladed screwdriver thru the manifold hole, turn the oil pump shaft a little bit and try to install the distributor again.
Old Jul 16, 2009 | 07:36 PM
schottout's Avatar
thanks
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
